Ggogo2368
Dec 19, 2019Aspirant
Home network security issues
Need help with a lot of issues on my home network. Using the Orbi RBR50 with one satellite and the Orbi outdoor extender. I have contacted Gearhead support numerous times without resolution (do not be...
CrimpOn
Dec 19, 2019Guru - Experienced User
Ggogo2368 wrote:
several ipv6 addresses appeared (which I have ipv6 off at the router)
My impression may be incorrect, however I believe that Orbi support for IPv6 has no effect on other devices inside the LAN. i.e. if a device in the LAN is set up to support IPv6, it will merrily blast away with IPv6 packets, especially broadcast packets. When I put Wireshark in promiscuous mode and capture only IPv6 packets, there are devices on my network generating packets. I believe the default for a lot of devices is to support both IPv4 and IPv6 (it certainly is for Windows)
