Raiden78
Nov 17, 2019Aspirant
Home network
I have an Orbi RBR40. Intention is to use it as a mesh to improve WiFi access across the house. That works fine. I also discovered the Circle functionality, which I really want to retain. I attac...
- Nov 17, 2019
you're having issues because you've got multiple routers (running in router mode) on your network. you've got a double nat
https://kb.netgear.com/30186/What-is-Double-NAT
If you're only using the orbi for wifi coverage, the easiest option is to place it in AP (access point) mode. You lose the ability to run disney circle but the wifi will work fine, the ethernet ports will all work, and you'll still be able to use the fritzbox as you are.
Nov 17, 2019Guru - Experienced User
- Raiden78Nov 18, 2019Aspirant
Hi Plemans,
Thanks a lot for the prompt answer. I will investigate it from there. I was starting to like Circle, so I will probably retain the situation and find another way to access the NAS from the computer (e.g. FTP or WebDav).
