00chris00
Jan 20, 2021Aspirant
home Orbi configuration issue with VPN for work
Problem Statement: I am running an Orbi RBR50 and satellite mesh network for home wifi. It works absolutely perfectly for a range of devices with perfectly adequate speeds - I am really happy with ...
00chris00
Jan 27, 2021Aspirant
Hello CrimpOn , thank you for your reply.
My apologies, I replied straight away, but now when I look that reply is not there.
Clearly user error. But I put a lot of time into that reply. This is Attempt 6. (shall try and split the message into smaller chunks)
Good idea re the speed test. I had been quite loose with my terminology, and was in fact referring to link rate.
