00chris00
Jan 20, 2021Aspirant
home Orbi configuration issue with VPN for work
Problem Statement: I am running an Orbi RBR50 and satellite mesh network for home wifi. It works absolutely perfectly for a range of devices with perfectly adequate speeds - I am really happy with ...
00chris00
Jan 27, 2021Aspirant
Configuration Settings
I really do not know what I am doing here, and could not explain why or if any of the changes made have had any effect.
I made them as a desperate attempt, knowing that I could always revert back to factory settings if need be.
I did:
- set Static IP (I think this was a mandatory pre requisite for the following setting)
under internet setup > advanced
- Advanced > Advanced Setup > VPN Service "Enable VPN Service"
- Advanced Setup > UPnP off
The effect of these changes was to make the link rate appear better in the app, but ultimately they didn't fix the whole problem.
