hariou
Dec 22, 2019Aspirant
home orbi: roaming
Hi. When walking around the house with several satellite access points, will the connected device automatically connect to the access point with highest wifi strength? I understand that the device ...
CrimpOn
Dec 22, 2019Guru - Experienced User
My experience is that my Sony smartphone and my Samsung tablet would both switch from the router to the satellite (and back) as I moved from one to the other. I had "Fast Roaming" checked in the Advanced WiFi Setup options. My (flawed) experiment was to open the Orbi "Attached Devices" page on the phone or tablet, note where the device was connected and then go (downstairs) to the other. Within two minutes, the display would indicate connection to the other. Same thing going back the other way.
So, (a) Yes, devices will roam if they are programmed to roam (phones, tablets, maybe laptops). Things that are not expected to move generally are not programmed to roam (TV's, IP cameras, etc.) (b) I actually do not know how "fast" they will switch.
