Skyzoomer's avatar
Skyzoomer
Home Orbi using cheap router on satellite for 3rd network
Friend needs mesh coverage with 3 separate networks for her large two story home .
If she buys a regular home Orbi 3 pack, she can use the built-in guest network and end up with two separate secure networks.  Is that right?
Now for the 3rd secure network, suppose I attach a cheap router using ethernet cable to one of the satellites as an access point.  Then use that as the 3rd secure network.  I realize that the wireless from the attached router will compete with the Orbi satellite but they could be set to different channels on the 2.4 GHz band.  Would this work?
  • CrimpOn's avatar
    CrimpOn
    This is an interesting situation.  The intention of a "Guest" network is to have devices quarantined so that they cannot connect to any of the resources on the primary network OR connect to each other.  In this sense, yes, Orbi has two "secure" networks but they are different.  There is an option to " Allow guests to see each other and access my local network", which of course simply means that guests have the same access but do not have to know the primary Orbi login password.
    "Mesh" and adding another WiFi network with a different SSID are incompatible.  i.e. the Orbi primary and guest SSID's will cover anyplace that the router and satellites cover.  Adding a 2.4G access point to one of the Orbi's will create a localized WiFi that covers as much area as that access point covers.  When a person wanders away from good coverage, they simply lose WiFi.
    You might want to take a look at the Orbi Pro, which features three SSID's to begin with.  Yes, Orbi Pro's cost more, but then so does adding (and maintaining) another WiFi system.  There is a user forum for the Orbi Pro.  Maybe someone on that forum could offer advice.
    All this begs the question of "what need is this trying to address?"  (Especially when the dreaded "2.4G" WiFi is  mentioned.)  I can think of several things: Air B&B.  Someone renting a room.  Perhaps if you describe more about what three "secure" SSID's are intended to accomplish, people can offer more nuanced advice.
    • Skyzoomer's avatar
      Skyzoomer
      CrimpOn wrote:
      (((This is an interesting situation.  The intention of a "Guest" network is to have devices quarantined so that they cannot connect to any of the resources on the primary network OR connect to each other.  In this sense, yes, Orbi has two "secure" networks but they are different.  There is an option to " Allow guests to see each other and access my local network", which of course simply means that guests have the same access but do not have to know the primary Orbi login password.)))
      Yes, devices on the guest network able to see each other and access the internet but not able to access the the primary network in any way, is what is desired.
      ((("Mesh" and adding another WiFi network with a different SSID are incompatible.  i.e. the Orbi primary and guest SSID's will cover anyplace that the router and satellites cover.  Adding a 2.4G access point to one of the Orbi's will create a localized WiFi that covers as much area as that access point covers.  When a person wanders away from good coverage, they simply lose WiFi.)))
      The 2.4G access point will only serve the rooms in the house that family number-3 reside in.
      (((You might want to take a look at the Orbi Pro, which features three SSID's to begin with.  Yes, Orbi Pro's cost more, but then so does adding (and maintaining) another WiFi system.  There is a user forum for the Orbi Pro.  Maybe someone on that forum could offer advice.)))
      Trying to avoid the additional expense of the Orbi Pro 3-pack (~$500) vs the home Orbi 3-pack (~$250) which is 1/2 the price.  The owner of the house already has a cheap Netgear router that could be used as the access point so no expense there.
      (((All this begs the question of "what need is this trying to address?"  (Especially when the dreaded "2.4G" WiFi is  mentioned.)  I can think of several things: Air B&B.  Someone renting a room.  Perhaps if you describe more about what three "secure" SSID's are intended to accomplish, people can offer more nuanced advice.)))
      Owner (primary network), daughter's family (Orbi's guest network) and a rental family (cheap router as AP).  The rental family will be restriced to their own rooms only.  Daughter could roam the house except for the rental areas.  They want all to be isolated from each other for privacy reasons.
      • CrimpOn's avatar
        CrimpOn
        Yes, this makes sense, as long as you have a way to connect the old Netgear router to the nearest Orbi.
        One tiny clarification: the daughter will be able to access the internet, but not connect to any other devices on the primary OR the guest networks.  That option is "all or nothing".  Probably not of interest unless she wants to print something on a WiFi printer.
        It's not clear (to me) what the "privacy concerns" are.  internet traffic goes from the device, through the Orbi, to the internet and back.  Data packets do not go to other devices - - - unless, of course, the Orbi administrator does something sneaky like "mirroring" all of the traffic out Port 1, which would capture everything from everybody.  Might be worth giving that issue some more discussion.
