vt15
Dec 18, 2019Aspirant
Home security for beginners
Hi, With the default settings on an orbi router I see my PC which is running mcafee firewall is detecting and blocking connection attempts on various tcp ports. Is there any way to block more ...
vt15
Dec 19, 2019Aspirant
Hello,
Thanks for your reply.
I compared the orbi logs and there is no entry at this time in those logs.
So I have events like this coming through to my PC:
The PC x.x.x.x tried to connect to TCP port 55026 on your PC without your permission
Various IP addresses are listed like:
49163, 49164, 49166, 49167, 49168, 49169
CrimpOn
Dec 19, 2019Guru - Experienced User
Interesting. Did the report give an actual IP address? (not "x. X. X. X")
The other numbers do not look like IP addresses. They appear to be TCP port numbers.
