BVDpa
Aug 12, 2019Aspirant
Home Wi-Fi Upgrade Question
I am currently using an old Apple Airport router in my 2400 sq foot home and it has provided good wi fi connections for many years. I am finally going to upgrade my system and am considering the purchase of either the Nighthawk AX600 or the Orbi RBK23 system.
I am not a gamer, and currently only have 2 iPhones, 2 Tablet, 2 iMacs, and a couple wi fi speakers.
Does anyone have any recommendations? Thanks
- nicholbLuminary
It really depends on your home. Is a single router currently able to provide good signal strength throughout your house? If so go with a good single router to replace. If you are having problems with reception in parts of your home, then a mesh router system might be the answer.
- BVDpaAspirant
Thanks for your recommendation.
