Parth_Goyal
Sep 30, 2020Aspirant
Home WiFi: Mesh vs WAP
 I'm looking for setting up my home network. I have 5 Floors(Residence) + 1 Floor(Maintainence). Entire home's on automation so network would be very populated. On maintainence floor there is modem fr...
- Sep 30, 2020
Parth_Goyal wrote:Thanks.
So as a final solution is it that Orbi Mesh is better than WAP? But, if WAP supports IEEE 802.11r (which is for smooth handoff) then it is also great.
And if a mesh is installed then caution should be taken while selecting the switch.
Final installation:
Modem(Maintainence Floor) >RBK50 Router Router Mode(Maintainence Floor) >Switch Unmanaged non green >RBS50 (on each floor)
A tri-band Orbi mesh system will perform far better than an access point, as they don't have to repeat the signal, and they have a dedicated backhaul. The RBR850 and RBR750 have a super fast backahaul channel, which will give you far better performance than Access Points. And the RBK853 and RBK753 have great coverage.
Sep 30, 2020Guru - Experienced User
Non managed, non green ethernet switches are preferred. NGs DGS-105/108 should work ok. I haven't tested these.
I do have D-Links DGS-105/108s and HP ProCurve 1400/1800 series and these do work.
Parth_Goyal wrote:I'm looking for setting up my home network. I have 5 Floors(Residence) + 1 Floor(Maintainence). Entire home's on automation so network would be very populated. On maintainence floor there is modem from ISP and ethernet wire running to all the other 5 floors. So, my entire backhaul is wired.
What would be better
- Modem(Maintainence Floor) >Router(Maintainence Floor) >Switch >WAP(on each floor) All WAPs with same SSID and passwords
 - Modem(Maintainence Floor) >OrbiRouter(Maintainence Floor)> Switch >OrbiSatellite(on each floor)
 *Star topology in both cases. WAP: WirelessAccessPoint. Orbi: NetgearMeshWiFi
I'm looking for a robust solution with
- Seamless switching while going from one floor to another
 - Fast communication b/w all devices in network
 - Efficient traffic management
