Parth_Goyal
Sep 30, 2020Aspirant
Home WiFi: Mesh vs WAP
 I'm looking for setting up my home network. I have 5 Floors(Residence) + 1 Floor(Maintainence). Entire home's on automation so network would be very populated. On maintainence floor there is modem fr...
- Sep 30, 2020
Parth_Goyal wrote:Thanks.
So as a final solution is it that Orbi Mesh is better than WAP? But, if WAP supports IEEE 802.11r (which is for smooth handoff) then it is also great.
And if a mesh is installed then caution should be taken while selecting the switch.
Final installation:
Modem(Maintainence Floor) >RBK50 Router Router Mode(Maintainence Floor) >Switch Unmanaged non green >RBS50 (on each floor)
A tri-band Orbi mesh system will perform far better than an access point, as they don't have to repeat the signal, and they have a dedicated backhaul. The RBR850 and RBR750 have a super fast backahaul channel, which will give you far better performance than Access Points. And the RBK853 and RBK753 have great coverage.
Parth_Goyal
Thanks.
Final installation:
Mstrbig
Sep 30, 2020Master
Final installation:
