t0lbert
Jan 23, 2020Aspirant
homekit router settings?
hey all,
what are the best settings when dealing with iot and homekit with the orbi mesh system?
Sort By
Try setting manual channel 1, 6 or 11 on 2.4Ghz and any unused channel on 5Ghz.
Armor, Circle, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).Adding IoT, you may need to temporarily disable the 5G SSID broadcast while you get the 2.4Ghz only IoT connected to Orbi. Then re-enable the 5G SSID broadcast afterwards. Under Advanced Tab/Advanced Settings/Wireless Settings
- t0lbertAspirant
done. will come back with result. thank you.
:smileywink:
