Rioo
Jun 03, 2022Guide
HomeKit Router Support for Netgear Orbi
To the Netgear Support Team, When will you integrate Apple HomeKit Router on the Orbi and Nighthawk systems? It's pretty sad that other vendors like Linksys and Amazon have been able to do this ...
KevinLiT
Jun 03, 2022NETGEAR Moderator
Hello Rioo,
Welcome to the NETGEAR Community!!!
I understand that you would like the Apple HomeKit Router integrated with our Orbi mesh systems. I will bring this feature up with my team as a future feature recommendation for the Orbi mesh systems.
Thank you for this suggestion!!!
Best,
Kevin
Community Team
- RiooJun 04, 2022GuideHi Kevin,
Thanks for the response.
If you could let us know the outcome about this as many people are wondering and it would let the consumer know if they should invest in the product?- CrimpOnJun 04, 2022Guru - Experienced User
Does this article accurately describe the desired integration of Apple Homekit into Netgear routers?
- michaelkenwardJun 08, 2022Guru - Experienced User
- ags118Dec 03, 2022AspirantHi Kevin,
Can you also bring it up with the Nighthawk team? This is the topic on HomeKit Router Support. Or do you know if this is set up already? I can’t seem to find anything.
Ashley
