tregan01
Jul 22, 2019Guide
HomeKit Router
Will Netgear (Orbi) support iOS 13 with a HomeKit Router?
tregan01
Jul 22, 2019Guide
HomeKit-enabled routers (supported with iOS 13)
Enabled routers bring an extra layer of security to your smart home. Use the Home app to control which services your HomeKit accessories can communicate with in your network and on the internet
Jul 22, 2019Guru - Experienced User
So are you asking if Orbi has security features? Circl and Armor are an added feature to Orbi systems. These are additional security features that can be enabled on the Orbi system.
You'll have to ask Apple what devices there Homekit products support and if they work with Orbi systems. General Apple iphones and pads work with Orbi.
