tregan01
Jul 22, 2019Guide
HomeKit Router
Will Netgear (Orbi) support iOS 13 with a HomeKit Router?
Mstrbig
Aug 30, 2020Master
NEW technology where no hubs are needed will dominate the smart home industry. Even Amazon is moving away from it, with their "Certified for Humans" technology and Google is following. More and more inexpensive devices are on the market fueling the change.
An Orbi RBK23 system would totally cover a 2100 sq ft. home.
With that many networks it will definitely slow the WIFI Down, hence why your speed suffers.
UW
Aug 30, 2020Guide
You're right, I should have been fine with the RBK23 and it was woefully inaduquate to blanket our home even with one satelite. I had to return it after a few weeks testing it out and it was horribly slow. There were spots indoors that didn't get coverage at all - before even adding Arlo hubs. Our walls (interior and exterior) are solid and thicker than new stick and cardboard homes in the US. I upgraded to the RBK53 (RBR50 + 2 RBS50 satelites) and that dramatically improved performance, coverage, and even extended outdoors by placing one of the satelites by a window and the main router by another window. It's why I'm leaning towards Linksys, not only for it's "coming soon" HomeKit enabled feature, but the kit I'm looking at getting would have 4 nodes which will give me greater flexibity to blanket indoors and even an outdoor structure.
I like your idea of "NEW technology" where no hubs are needed. Please influence Netgear to ditch Arlo hubs and have their cameras connect directly to Orbi or to be able to be paired with any WiFi network. Arlo hubs are horrible in that not only do they broadcast their own private WiFi network, they don't even play with other Arlo Hubs. When you pair a camera to a hub, that's it, it won't "load balance" or float between available Arlo Hubs on a single network. That was a huge surprise and disapointment.
- UWSep 26, 2020Guide
Good bye Orbi and hello Linksys Velop that are now officially HomeKit enabled! I returned my Orbi RBR50 kit with two satellites yesterday and have been enjoying my new Linksys Velop nodes. Per node the coverage is actually much better, they take up less than half the space, and to boot they improve my network security now that they "Work with HomeKit"! I think the only thing I miss about Orbi is Circle, but that's easy enough to replace given NetGear only offered "1st gen Circle".
https://www.linksys.com/us/support-article?articleNum=316767
