ncsu's avatar
ncsu
Home/Shop Router
I have a shop approximately 150 ft. behind my house that I've run cable and internet to.  I ran Cat 6 to it and was told I needed a small router with an access point to improve the signal.  Which sma...
  • FURRYe38's avatar
    If your using Orbi as your main host router, then you only need a LAN line out to the shop. Then you can get a low cost router that can be configured for AP mode. Once in AP mode, connect it to the LAN side and this will be your wifi access point for anything at the shop. You can even use it's open LAN ports for wired connections as well.
