Johnboy00
Apr 04, 2019Aspirant
Honewell T9 Smart Thermostat and Orbi RBR50 Router and RBS50 Satelite
Recently purchased Honewell T9 Smart Thermostat.
I connected the device successfully to my Orbi RBR50 Router network, and shows "connected to WiFi" on thermostat, but "No Internet or Cloud connectio...
Apr 05, 2019Guru - Experienced User
hat Firmware is currently loaded?
What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials when wirelessly connected.
Try enabling Beamforming and MIMO. Under Advanced Tab/Advanced Settings/Wireless Settings
Johnboy00 wrote:
Recently purchased Honewell T9 Smart Thermostat. I connected the device successfully to my Orbi RBR50 Router network, and shows "connected to WiFi" on thermostat, but "No Internet or Cloud connection". I have successful internet connection on all other devices. The error message is "socket connection failed. WiFi router is blocking peer to peer connection. Please check your router setting to allow proximal connectivity" How can I " Unblock, or allow proximal connectivity " to allow internet access for this device? In router settings, the device is "allowed" , but I think this is only for WiFi network. Security is set to "WPA2-PSK" Thanks
Johnboy00
Apr 05, 2019Aspirant
Arris TM1602 Modem >> NG Orbi RBR50 Router
Router Firmware just updated to latest rev. Version V2.3.1.44
2500 Sq ft RBR50 router + 1 Satelite RBS50
Thermostat is less than 25 feet from router (connecting fine to WiFi, but router won't allow internet connection for thermostat)
I enabled Beamforming and MIMO. ...No change.
I will try setting manual channel
Thanks
- FURRYe38Apr 05, 2019Guru - Experienced User
