Johnboy00
Apr 04, 2019Aspirant
Honewell T9 Smart Thermostat and Orbi RBR50 Router and RBS50 Satelite
Recently purchased Honewell T9 Smart Thermostat.
I connected the device successfully to my Orbi RBR50 Router network, and shows "connected to WiFi" on thermostat, but "No Internet or Cloud connectio...
Johnboy00
Apr 05, 2019Aspirant
Arris TM1602 Modem >> NG Orbi RBR50 Router
Router Firmware just updated to latest rev. Version V2.3.1.44
2500 Sq ft RBR50 router + 1 Satelite RBS50
Thermostat is less than 25 feet from router (connecting fine to WiFi, but router won't allow internet connection for thermostat)
I enabled Beamforming and MIMO. ...No change.
I will try setting manual channel
Thanks
Apr 05, 2019Guru - Experienced User
What is the distance between the router and satellite(s)?
