Webdad's avatar
Webdad
Honeywell RedLink Gets IP from Orbi but doesn't connect to Honeywell
Recently installed the Honeywell thermostat with the REDLink connection.  The REDLink won't get an internet connectcion to Honeywell.   I've tried plugging into a switch off the RBR50 and directly ...
  • Webdad's avatar
    Webdad
    Nov 15, 2021
    Issue resolved, posting this here for any other travelers that come this way.
    After going over the preface to the instructions with a fine tooth comb, there was a passing reference to needing to bond a thermostat to the REDLink prior to attempting to connect to the honeywell redlink servers.  After finding out how to do that and completing that activity, the interface module linked up first time.
    Sorry for the confusion.
