TCDale's avatar
TCDale
Follower
May 25, 2018
Honeywell Thermostat 8580WF
Had a failure connecting to my Honeywell 8580 thermostat when I changed to the Orbi router. It could not find / connect to the new router. Here is what worked for me.
1.) Disconnect the old WiFi by going into system set up on the thermostat. Change setting 900 to 0. Then exit the system set up screen.
2.) The display will show ‘WiFi disconnected” for one minute, then should go to “WiFi set up” mode. Then follow normal WiFi network set up steps. Bingo, I was connected.
This process is listed on page 47 of the Honeywell user guide. System set up process is listed on page 51-58.
1 Reply
  • DarrenM's avatar
    DarrenM
    Sr. NETGEAR Moderator
    Hello TCDale
    Thanks for the tip on how to get this working.
    DarrenM
