Maradacash
May 14, 2020Follower
Hook up satelite with ethernet
My satelite is probably out of range, though I do have an ethernet connection back to the router. Can I hookup the satelite via ethernet And sync?
CrimpOn
May 14, 2020Guru - Experienced User
Yes. Probably a good idea to connect them in the same room with an ethernet patch cable to verify everything OK before moving it to the remote location.
