Maradacash
May 14, 2020Follower
Hook up satelite with ethernet
My satelite is probably out of range, though I do have an ethernet connection back to the router. Can I hookup the satelite via ethernet And sync?
May 15, 2020Guru - Experienced User
Its recommended to wirelessly connect the RBS first near the RBR. Then wire connect it to ensure the RBS syncs correctly. Then place in it's remote location and connect it to ethernet wire there.
