Daddykev
Aug 21, 2020Aspirant
Hoping to get my devices to choose 5ghz on Orbi RBK23
hi there, I recently installed my orbi and its working quite well. I have a 2 story plus basement house. My router is in my basement and a satellite is on each level of the house. I'm finding in my on...
GMoGoody8
Aug 21, 2020Luminary
The GUI setting for transmit power is for all devices. If you feel adventurous you could telnet into the Satellite and try to reduce the transmit power that way. There is a thread for advanced users with tips and tricks that might have the commands for that. Caveats to doing stuff like this is you could brick devices or screw them up, and sometimes settings set this way don't survive a reboot.
Daddykev
I would definitely not be up for that, I am a complete idiot.
I'll try to look into the GUI setting
- GMoGoody8Aug 21, 2020Luminary
In the GUI transmit power can be found. Advanced Tab --> Advanced Setup --> Wireless Settings --> Each Radio will have a Transmit Power Control Drop down with tha ability to select 100%, 75%, 50% and 25%
- MstrbigAug 21, 2020Master
Usually the main reason your device will keep connecting 2.4Ghz is because the 5Ghz signal is too weak. With that said, turning down the power on 2.4Ghz may help you connect 5Ghz, however, the signal may be so weak you will get slow WIFI speeds or intermittant disconnects. If possible can you move the satellite to a closer location?
You can download and run a WIFI analyzer like WifiInfoView or Netspot. They will give you some information on how your router satellites' WIFI are performing.
