sh2sg
Jul 31, 2019Apprentice
horrible 2.3.5.30
RBR50 + 2x RBS50, wireless backhaul. After upgraded to 2.3.5.30, the 2 satellites keep disconencted from RBR50, sometimes satellites reconnected back to RBR50 after few mins, sometimes they didn'...
- Jul 31, 2019
Try a factory reset on the RBR. If you only reset the RBS and not the RBR after the FW update, this could help.
I setup my RBK50 system again in AP mode, yesterday. RBS is wired though. No issues here.
sh2sg
AP mode.
They used to be very stable in the past one year with 2.2.x.x firmware
Jul 31, 2019Guru - Experienced User
- sh2sgAug 04, 2019Apprentice
I did factory reset on RBR50 3 days ago and it ... did help. I didn't encounter any disconenction so far. Thanks for the tip.
I hope I don't need to do factory reset on all units regularly...
- FURRYe38Aug 05, 2019Guru - Experienced User
Glad the reset helped. Seems that when new FW updates come out, if users see problems after the FW update, a reset maybe needed.
Do a backup configuration to file for safe keeping.
Enjoy :smileywink:
- Retired_MemberAug 06, 2019
sh2sg wrote:I did factory reset on RBR50 3 days ago and it ... did help. I didn't encounter any disconenction so far. Thanks for the tip.
Why did you upgrade your firmware?
