sh2sg
Jul 31, 2019Apprentice
horrible 2.3.5.30
RBR50 + 2x RBS50, wireless backhaul. After upgraded to 2.3.5.30, the 2 satellites keep disconencted from RBR50, sometimes satellites reconnected back to RBR50 after few mins, sometimes they didn'...
- Jul 31, 2019
Try a factory reset on the RBR. If you only reset the RBS and not the RBR after the FW update, this could help.
I setup my RBK50 system again in AP mode, yesterday. RBS is wired though. No issues here.
Jul 31, 2019Guru - Experienced User
sh2sg
Aug 04, 2019Apprentice
I did factory reset on RBR50 3 days ago and it ... did help. I didn't encounter any disconenction so far. Thanks for the tip.
I hope I don't need to do factory reset on all units regularly...
- FURRYe38Aug 05, 2019Guru - Experienced User
Glad the reset helped. Seems that when new FW updates come out, if users see problems after the FW update, a reset maybe needed.
Do a backup configuration to file for safe keeping.
Enjoy :smileywink:
- AnonymousAug 06, 2019
sh2sg wrote:I did factory reset on RBR50 3 days ago and it ... did help. I didn't encounter any disconenction so far. Thanks for the tip.
Why did you upgrade your firmware?
