hokievol
Mar 13, 2019Tutor
Horrible customer service
I cannot beileve how bad customer service is on a product that cost so much. You can see from the screenshot below the Orbi router is not recognizing the cable connection, but . I've had connection...
- Mar 18, 2019
I talked to Comcast 3 times to make sure all was well before reaching out to Netgear. They reactivated the modem, etc. I bought the CBR40 in August and had no issues until now.
I was able to get my case escalated to Tier 2 and they got me taken care of. I attached one of the screenshots, Home setup screen didn't recognize the cable connection even though the internet worked at the time. Also, the Event Log was blank. Something was wrong with the OS or hardware. Received a replacement Saturday and installed it. Everything works fine now.
It was painful to have to spend 2 hours to do something that should have taken 20 minutes. Tier 1 kept asking me to change wifi settings when I was having issues via ethernet. Thankfully Gigi with Tier 2 was able to get it resolved.
hokievol
Mar 13, 2019Tutor
CBR40. That is whay I posted on this part of the community. Tried to enter the model but it is not on the list.
FW is the latest, 2.2.1.210_1.0.8
Again, in the Orbi with built in modem section of the community, it is all in one.
I did everything you describe multiple times. Explained this to tech support on two separate calls. They ultimately said watch it for 24 hours and call us back. I asked to be escalated to tier 2 and of course no resources are avaialble. No one has called back fron tier 2 either.
Mar 13, 2019Guru - Experienced User
Ok, or inital post didn't have any model reference.
So did you first contact your ISP to have them activate and associate the CBR40 with there service? This has to be done first for most cable ISP operators.
Who is your Internet provider?
- hokievolMar 18, 2019Tutor
