XL25A
Jan 14, 2023Tutor
HORRIBLE wifi speed but ULTRAFAST via ethernet ports
Issue: Cable modem (SPECTRUM) delivering 350+ Mbps INBOUND with near equal throughput (measured via FAST.COM) to devices via Ethernet ports on two satellites. Wifi throughput, HOWEVER, typically...
CrimpOn
Jan 15, 2023Guru - Experienced User
Could you do me a favor and install WiFi Info View on the Windows laptop?
https://www.nirsoft.net/utils/wifi_information_view.html
On the "Options" menu, there is a choice of Channel Summary Mode. My 5G channel 48, for example, shows as 18.2%.
Thanks
XL25A
Jan 16, 2023Tutor
Here are 2 images. Not sure how to fully glean information from this.
Also, current speed with just the RBR50 Wifi on iPhone/iPad is 6Mbps MAX while my PC is around 60Mbps and the iMac 70Mbps
