evolve911
Dec 31, 2018Follower
House WIFI Help (4 levels)
Current System (all on current firmware)
- RBK50 x 1
- RBS50 x 2
- Fios Router (wireless turned off/ routing through RBK50, wireless to both RBS50)
Current house:
- Basement (workout ...
Chuck_M
Jan 15, 2019Mentor
Your first problem MAY be caused by the second. e.g. devices falling off line may be because of insufficient communications between the Orbis.
Would be good to spend a few minutes answering questions like How far are orbi's from each other in feet (yes, through walls)? What is building material? What Firmware is Orbi running?
I thing a good rule of thumb is you would always want a wired network versus an Radio Freq (RF) one.
I have my 2 RBS50s hard wired because my home is a very long ranch. I havethe main router (RBR50) where cable modem is and two extremely long ethernet cables that go to each satellite. By hard wiring you are no longer dependant on RF and any potential intereference that may occur with backhaul. Ethernet backhaul is certainly faster and more reliable than RF.
The next thing I would do if I were in your shoes is conduct a signal survey of your home. Are there competing signals from neighbors etc that may be "jamming" the effectiveness of your router? Try downloading on Android or Iphone any "WiFi analyzer" software and take a look at the channels on both the 2.4 and 5ghz bands... do you see "peaks" that are close to your router that belong to your neighbors or are unaccounted for?
You will probably see a printer "peak" -- that is normal. You will also see on the 5ghz band a "hidden SSID" peak... that is also normal and is in fact your ethernet RF backhaul channel.
Answer these things first and lets go from here.
