evolve911
Dec 31, 2018Follower
House WIFI Help (4 levels)
Current System (all on current firmware)
- RBK50 x 1
- RBS50 x 2
- Fios Router (wireless turned off/ routing through RBK50, wireless to both RBS50)
Current house:
- Basement (workout ...
Jan 15, 2019Guru - Experienced User
What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials.
Yes you can add switches to the mix. Be sure they are non managed, non smart and non green ethernet switches.
