ShankarHokie
Sep 09, 2020Apprentice
House wired with CAT6. Can I use a network switch instead of satellites and wifi
Hello all, As I discussed in March, our new home is fully wired with CAT6 cables wherever a TV or Computer is going to be. Probably 10 locations. https://community.netgear.com/t5/Orbi/Orbi-RBK...
- Sep 09, 2020
ShankarHokie wrote:The house will be 2800 sq ft. 3 levels. Nothing to be connected in the basement. 2 offices and a media center in the first floor. Network connected garage door opener. 4 media ceners in the 2nd floor. All of these spots have network drops with cat 6 wiring.
Now that I think about it, I might have to connect at least one RBS for our cell phones to connect to the home network vis wifi.
I was hoping that I can connect all my TVs and media devices to the wired network without having the satellite next to them.My home has a similar setup to what you are askiing. My Orbi system is RBR50 router, 2 RBS50 satellites, 1 RBS40V satellite.
The Orbi system is a plus because I love having full WIFI throughout my home for phones, tablets, cameras, and Amazon Echos and smart devices.
With that said, I go from the ISP modem to the Orbi router to a large switch with cables to various rooms for hard wired devices. In 2 strategic office areas I have a satellite connect to the cable from the switch and then plugged a switch into each of the satellites for more hard wired connections in those areas.
The end result is I have full fast wired and WIFI coverage throughout my home and a separate building.
Sep 09, 2020Guru - Experienced User
Yes you can. Please follow this guide for wire connecting the RBS to the RBR using a switch:
- ShankarHokieSep 09, 2020Apprentice
Thanks FURRYe38 . I was wondering if I even need to use the RBS50.
- FURRYe38Sep 09, 2020Guru - Experienced User
The RBS would be considered as wired APs if you used them if your not looking for wireless coverage on the area then you may not need them at all.
RBS are for additional wifi coverage through out the home and in remote locations were wifi signal may low or not existent.
What is the size of your home? Sq Ft? IF you have a small home, then you may only need the RBR. I have a 5000sq ft home and have 1 RBR and 1 RBS and this works well for my size of home.
30 feet or more is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected. https://kb.netgear.com/000036466/How-far-should-I-place-my-Orbi-satellite-from-my-Orbi-router- ShankarHokieSep 09, 2020Apprentice
