vrvrsloworbi's avatar
vrvrsloworbi
how can disabled 2.4Ghz in RBR50?
My Wi-Fi is ridiculously slow when use RBR50's 2.4GHz -  Average 20~10Mbps. even try right next to it.   but when it's connected to 5GHz - Average 560~500Mbps   so I want to disabled 2.4GHz in RB...
  • CrimpOn's avatar
    CrimpOn
    Dec 07, 2022
    My phone exhibits a similar behavior.  When I arrive home, the first WiFi signal it encounters is the satellite in the garage.It seems that the instant that signal is strong enough to recognize, the phone connects at 2.4G.  After I enter the house, sometimes I notice that it remains connected at 2.4G for longer than I would expect, and then it switches to 5G by itself.
    If I turn off WiFi and then turn WiFi back on again, it immediately connects at 5G.
    I sincerely wish that Netgear had provided more options for handling the WiFi radios and naming the SSIDs, because this issue is easily the most common question on the forum and users are never happy with the situation.  But, they didn't and show no indication of changing.  My understanding is that other popular mesh WiFi systems have the same setup, and probably the same complaints.
