debrasunshine
Oct 24, 2018Follower
How can I connect an external hard drive to Orbi Router RBR 50 via USB?
I would like to connect an external hard drive via USB to the Orbi RBR50 router to back up a macbook pro via time machine. how can i get USB port to work?
- Nov 07, 2018
Hi All,
I have checked this with the team. Orbi has not been updated to use Readyshare features as of right now it only officially supports Readyshare print for printers via the USB.
Blanca
Community Team
Blanca_O
Oct 24, 2018NETGEAR Employee Retired
Welcome to NETGEAR Community!
ReadyShare feature for Orbi only officially suppprts ReadyShare print for printers via the USB. However, there are few users who mentioned that their USB HDD were detected by the router. Please allow me to check this first and I will get back to you.
Blanca
Community Team
fritzboyle
Nov 05, 2018Aspirant
i would be interested if there is a way for me to use my USB HD connecte to the router
- FURRYe38Nov 05, 2018Guru - Experienced User
https://community.netgear.com/t5/Orbi/Does-Orbi-RBK50-support-USB-Connected-hard-drives/td-p/1332052
- Blanca_ONov 07, 2018NETGEAR Employee Retired
Hi All,
Blanca
Community Team- FURRYe38Nov 07, 2018Guru - Experienced User
Thank you for the updated info.
