debrasunshine
Oct 24, 2018Follower
How can I connect an external hard drive to Orbi Router RBR 50 via USB?
I would like to connect an external hard drive via USB to the Orbi RBR50 router to back up a macbook pro via time machine. how can i get USB port to work?
- Nov 07, 2018
Hi All,
I have checked this with the team. Orbi has not been updated to use Readyshare features as of right now it only officially supports Readyshare print for printers via the USB.
Blanca
Community Team
fritzboyle
Nov 05, 2018Aspirant
i would be interested if there is a way for me to use my USB HD connecte to the router
Nov 05, 2018Guru - Experienced User
https://community.netgear.com/t5/Orbi/Does-Orbi-RBK50-support-USB-Connected-hard-drives/td-p/1332052
- Blanca_ONov 07, 2018NETGEAR Employee Retired
Hi All,
Blanca
Community Team- FURRYe38Nov 07, 2018Guru - Experienced User
Thank you for the updated info.
- completelyNov 14, 2018Guide
you call THIS as a SOLUTION???
waste of my time.
- michaelkenwardNov 15, 2018Guru - Experienced User
The answer was for debrasunshine. The only time wasted was when you posted your message.
- wmanning7538Nov 29, 2018Aspirant
Is there any anticipated time frame of when this capability will be available?
- FURRYe38Nov 30, 2018Guru - Experienced User
NG does post when changes will be made, if any. Its possible that USB drive support may not be seen on Orbi as well. Something only NG knows what will happen.
I recommend you find alternate USB drive support solutions. There are USB to LAN adapters that can be used to put a USB drive on a network. Something to look into.
