entyrion
Apr 15, 2019Aspirant
How can I disable Netgear analytics on Orbi RBR50?
For my Orbi RBR50 system, FW v2.3.1.44, I am trying to disable the Netgear Analytics functionality, but cannot find the opt-out controls. The instructions at https://kb.netgear.com/000038661/ow-do-I-...
- Apr 23, 2019
Hi All,
I have checked this with the team, the router analytics data collection on Orbi is enabled and no option to turn it off. This router capability will allow us to get certain technical data that will surely help us improve our products. The collected data are secured and confidential. Please check this KB link: https://kb.netgear.com/000038665/What-is-router-analytics-data-collection-for-my-NETGEAR-router
Blanca
Community Team
Blanca_O
Apr 16, 2019NETGEAR Employee Retired
Hi Everyone,
Thank you for bring this to our attention. Please allow us to check this said feature and we'll get back to you.
Blanca
Community Team
- Blanca_OApr 23, 2019NETGEAR Employee Retired
Hi All,
Blanca
Community Team- CrimpOnApr 23, 2019Guru - Experienced User
Thanks for checking. I hope you were able to impress upon "the team" (1) somebody should update Netgear's web site to indicate that Nighthawk and Orbi routers collect anlytics, and (2) it does not seem reasonable that Nighthawk users have the option to disable data collection but Orbi users do not. It is one checkbox on a menu. How hard can that be?
- entyrionApr 24, 2019Aspirant
Thanks, this technically answers my question, but the obvious next step is a feature request to disable the analytics collection in the same way as has already been implemented on the Nighthawk. Is there a formal process to do so?
- CrimpOnApr 24, 2019Guru - Experienced User
Yes, Netgear has a forum to request software changes: https://community.netgear.com/t5/Idea-Exchange-For-Home/idb-p/idea-exchange-for-home/label-name/orbi%20wifi%20system
In my (limited) experience, even the most trivial requests are usually ignored. It is not clear (to me) that Netgear engineers pay any attention to it (at least the Orbi section). My personal opinion is that Orbi is based on OpenWRT which is different from the software base for the Nighthawk line, and this makes implementing changes more challenging.
