Gruncle1
Mar 10, 2017Guide
How can I Monitor Traffic by Attached device
I have an ORBI RBK50 with one satellite. How can I monitor traffic by attached device. My ISP provider gives me very little bandwith and I have to use it carefully. If I knew which device was using how much,it would help. I looked at one solution that appeared to need me installng outside firmware on the router and I do not want to do that.
- ElyLuminary
Unfortunately monitoring how much bandwidth is being used by device is not possible at the momment, I don't believe you can load a different firmware into the device other than the official one.
- AndersOrbiInitiate
I really wish Netgear will add the possibility to monitor traffic, and give statistics for each device in the Orbi app.
Wishlist for app update:
- total data usage for all devices (day/week/month)
- total data usage pr device (day/week/month)
- current bandwith usage (total/each device)
With these features i am able to identify which device use most data, or which device use all bandwith.
- balpaughInitiate
I agree that this is a necessary feature. I like the Orbi system a lot, however with its limited ability to accomplish security tasks and analytics is disconcerting.
