smarcher
May 24, 2017Follower
How can I redirect the TCP port 25211 for use with LIMA?
I am trying to connect my Lima directly to the Orbi as peer-peer, I am supposed to redirect manually the TCP port 25211 to my Lima IP. Can not figure this out.
Thanks
You're looking for "port forwarding" instructions so that outside traffic going to port 25211 gets forwarded to the internal IP address of your Lima device. They have some general instructions here under "How to authorize ports?": https://support.meetlima.com/articles/207051206-How-to-make-your-router-work-best-with-Lima
Port forwarding controls for Orbi are accessible via the Advanced tab: http://orbilogin.com/adv_index.htm, under Advanced Setup. You can find the internal IP address of your Lima device under the Basic tab, by clicking on Attached Devices and looking at the Connected Devices list.
1 Reply
