RiverCityNet
Oct 05, 2020Aspirant
How can I see add-on satellite in Orbi app?
I’m using an Orbi system with router + 3 satellites (2 that came with the system + 1 add-on) to cover a large 2-story house with VERY thick walls. Right now, the network is configured like this: ...
- Oct 05, 2020
Adding a switch does not change the configuration. The Orbi router expects that satellites will be connected to one of the router LAN ports, not connected through the WAN port.
It appears from the term "structural limitations" that the Orbi router is not located next to the cable modem/router. My first thought would be to connect the add-on satellite using WiFi. Second would be to run an ethernet cable from one of the original devices.
Sorry not to be more positive.
Mstrbig
Oct 05, 2020Master
RiverCityNet wrote:Cable modem/router > Port 1 > RBR50 (via ethernet) + 2 RBS50 (wireless daisychain)
Cable modem/router > Port 2 > RBS40 (via ethernet)
It works fine, except the app always shows the satellite connected to the second ethernet port as being offline and not having any clients connected to it (even though it does).
Cable modem/router > Port 1 > NEW switch >>>
>>> [NEW switch] > Port 1 > RBR50 (via ethernet )
>>> [NEW switch] > Port 2 > RBS40 (via ethernet)
What do you think of this idea?
You cannot connect a satellite to the cable modem router and expect it to show up in the app or GUI or even work correctly. Move the wired connection to the RBS40 to the Orbi router. So Port 1 > RBR50 (via ethernet) + 2 RBS50 (wireless daisychain) and 1 RBS40 (via ethernet port 1 of Orbi router)
- MstrbigOct 05, 2020Master
Mstrbig wrote:You cannot connect a satellite to the cable modem router and expect it to show up in the app or GUI or even work correctly. Move the wired connection to the RBS40 to the Orbi router. So Port 1 > RBR50 (via ethernet) + 2 RBS50 (wireless daisychain) and 1 RBS40 (via ethernet port 1 of Orbi router)
Adding to this, if it is impossible to connect the RBS40 to the RBR50, then as stated your other option is to connect it via WIFI backhaul. Of cours it will matter how far the RBS40 is from the RBR50 router or closest satellite <-(using daisychaining). Yor second scenario will not change anything, as the RBS40 will still be connected to the ISP modem via switch.
