RiverCityNet
Oct 05, 2020Aspirant
How can I see add-on satellite in Orbi app?
I’m using an Orbi system with router + 3 satellites (2 that came with the system + 1 add-on) to cover a large 2-story house with VERY thick walls. Right now, the network is configured like this: ...
- Oct 05, 2020
Adding a switch does not change the configuration. The Orbi router expects that satellites will be connected to one of the router LAN ports, not connected through the WAN port.
It appears from the term "structural limitations" that the Orbi router is not located next to the cable modem/router. My first thought would be to connect the add-on satellite using WiFi. Second would be to run an ethernet cable from one of the original devices.
Sorry not to be more positive.
RiverCityNet
Thanks to all for confirming that this won't work unless the satellite is behind the Orbi router. That's what I figured, but I rely on the wisdom of this (very knowledgeable) crowd.
(Extra big ups to CrimpOn for the fast response!)
