ckosloski
Sep 02, 2019Aspirant
How can I use parental controls an Orbi without purchasing a subscription
I just purchased an Orbi today and it seems like it's not possible to setup an internet scheduler per device without paying a subscription on top of all the money I just spent. Is that correct?
ckosloski
Sep 03, 2019Aspirant
I was looking into OpenDNS. From what I could find, you had to use the Genie app to configure it, which apparently is no longer supported.
When you go to the download page, it seems like it tries to force you to download the new Orbi app.
If you close the app popup and scroll to the bottom of the page, you can download the Genie app. So now I was able to setup parental controls. Now to figure out hot to limit the internet time by device.
michaelkenward
Sep 03, 2019Guru - Experienced User
- michaelkenwardSep 03, 2019Guru - Experienced User
michaelkenward wrote:
There is also the direct way in:
https://netgear.opendns.com/sign_in.php
I forgot to add that this might also work in a browser on a mobile device.
In that way you might be able to get around Netgear's obstructive crippling of the apps.
