Beneficia
Oct 04, 2024Aspirant
How can you connect to the RBS50Yv2 to review its Configuration in Extender Mode Orbi Outdoor Sat
I have an Orbi Outdoor Extender (RBS50Yv2) and I think it is functioning properly in Extender mode, not Orbi mode, but I want to review the configuration but I seem unable to connect to it. I see t...
Beneficia
Oct 07, 2024Aspirant
Thanks for the reply : )
The extender is connected to the an Orbi Pro WiFi6 system. It is definitely connected, because I have done some testing and confirmed that more distant devices are not connected when the unit is unplugged and when I plug it back in the LED's glow Blue and then those distant devices connect once again. When I log into the Insight App I simply cannot find the device IP address by searching for the device and the MAC address.
Oct 07, 2024Guru - Experienced User
To see the RBS50Y, you can try using the Orbi app. I don't believe the Insight app is supporting of the Orbi Home product line. Orbi app is the Orbi home product line that supports that.
