emmaorbi
Dec 30, 2016Aspirant
How do I access the Orbi once it is in AP mode
The Android app works but I dont seem to be able to access the web interface. Thanks.
- Dec 30, 2016
To clairfy what I said. Connect to your router. View your connected devices list. Find the MAC address of your Orbi (most likely on the box it came with for verification) then connect to the IP address that is associated with the MAC Address of the Orbi.
netwrks
Dec 30, 2016Master
If you didn't statically configure an IP address on the Orbi in AP mode, check your routers connected / attached devices list. Look for the MAC Address of the Orbi.
- emmaorbiDec 30, 2016Aspirant
Can probably do this but how do I get into web interface via MAC address?
- netwrksDec 30, 2016Master
Ah I see, I used fing and the four other extender I have made me think I could not access the orbi this way - I was logging into the wrong one. Now to add the satelite and get rid of the extenders! Thanks!
