emmaorbi's avatar
emmaorbi
How do I access the Orbi once it is in AP mode
The Android app works but I dont seem to be able to access the web interface. Thanks.
  • netwrks's avatar
    netwrks
    Dec 30, 2016
    To clairfy what I said. Connect to your router. View your connected devices list. Find the MAC address of your Orbi (most likely on the box it came with for verification) then connect to the IP address that is associated with the MAC Address of the Orbi.
    Find your router manual here
