ZombieBacon's avatar
ZombieBacon
How do I broadcast 5 and 2.4 networks SSID’s on RBR20
Greetings, Using an RBR20 I need to broadcast both 5 and 2.4 networks SSID. Any help would be much appreciated.
  • FURRYe38's avatar
    Nov 12, 2019
    Do you mean having separate SSIDs on the Orbi? If so, NG doesn't support the separation of SSIDs on Orbi. The 2.4Ghz and 5Ghz are operated under 1 SSID. Orbi and the devices automatically get the devices connected to either frequency based on there support, signal and noise conditions.
    IF your having problems connecting devices to the Orbi you can temporarily disable the 5Ghz SSID broadcast while you get your 2.4Ghz devices connected to the RBR. Then re-enable the 5Ghz SSID afterwards.
    https://community.netgear.com/t5/Orbi/v2-5-0-38-undoes-SSD-split-is-there-a-fix/m-p/1816546/highlight/true#M73951
