Rogelio82
Feb 22, 2019Follower
How do I change my preset Network Key (Password)?
CrimpOn
Feb 22, 2019Guru - Experienced User
The WiFi password can be set by using a web browser to connect to the Orbi, usually at 192.168.1.1. On the "Basic" tab, select "Wireless" and the WiFi password is toward the bottom of the screen. Most people also change the Administrative Password from "password". That is on the "Advanced" tab, select "Set Password". This is also the place where you can input challenge questions that can be used to unlock the password if you forget exactly what it is (every character has match upper/lower case, etc.)
Was this what you wanted?
