todddel68
Jul 06, 2019Tutor
How do I change the Orbi satellites's password?
During initial setup I set a password that I now want to change. I can do that for the Router in the web interface settings but the satellite will still keep the 'old' password. No syncing withe the ...
- Jul 07, 2019
Try to remove the RBS from the RBR systems UI. Then factory reset the RBS then re-add it using the sync buttons on the RBR and RBS. The re-add should sync the PW to the RBS for whats set on the RBR.
todddel68 wrote:I have the same setup and it doesn't sync the admin password. I had the satellite reset and synced again but it didn't do anything. Changing the pw on the router is never synced onto the sat. This seems to be a common problem judging by the threads here which for some reason I cannot reply to as a new user. Some have it, some don't.
CrimpOn
Jul 06, 2019Guru - Experienced User
Which Orbi model is this, and which password? My RBR50 and RBS50 sync the passwords automatically (i.e. the WiFi login password and the Orbi administrative password). There is no password option on the satellite because the router controls both.
If the satellite is "stuck", I would do a factory reset on the satellite and resync it to the router.
todddel68
Jul 07, 2019Tutor
