todddel68
Jul 06, 2019Tutor
How do I change the Orbi satellites's password?
During initial setup I set a password that I now want to change. I can do that for the Router in the web interface settings but the satellite will still keep the 'old' password. No syncing withe the ...
- Jul 07, 2019
Try to remove the RBS from the RBR systems UI. Then factory reset the RBS then re-add it using the sync buttons on the RBR and RBS. The re-add should sync the PW to the RBS for whats set on the RBR.
todddel68 wrote:I have the same setup and it doesn't sync the admin password. I had the satellite reset and synced again but it didn't do anything. Changing the pw on the router is never synced onto the sat. This seems to be a common problem judging by the threads here which for some reason I cannot reply to as a new user. Some have it, some don't.
todddel68
Jul 07, 2019Tutor
Jul 07, 2019Guru - Experienced User
- todddel68Jul 09, 2019Tutor
Can't see how to "remove" it. However, I reset it to factory settings an resynced router and satellite and now the sattellite defaulted to the standard password and things are even worse cause now it has this pw everybody can find on the www and it can not be changed.
- CrimpOnJul 09, 2019Guru - Experienced User
Removing a satellite is simple, but sort of hidden. Turn off power to the satellite. Then go to the router web interface and look at Attached Devices. The satellite will show as "not connected" and there will be an option to Delete it. The option does not show up when the satellite is conneced and has power. (Not what I would have chosen, but that's what it is.)
I want to be sure and not buy one of this particular Orbi. What does the label on the satellite say for model number?
- FURRYe38Jul 10, 2019Guru - Experienced User
Once the satellite is removed and re-synced, the satellite automatically will pick up the PW set forth by the RBR. You can't change the satellites PW otherwise.
Let us know the model # of the RBS.
todddel68 wrote:Can't see how to "remove" it. However, I reset it to factory settings an resynced router and satellite and now the sattellite defaulted to the standard password and things are even worse cause now it has this pw everybody can find on the www and it can not be changed.
