todddel68
Jul 06, 2019Tutor
How do I change the Orbi satellites's password?
During initial setup I set a password that I now want to change. I can do that for the Router in the web interface settings but the satellite will still keep the 'old' password. No syncing withe the ...
- Jul 07, 2019
Try to remove the RBS from the RBR systems UI. Then factory reset the RBS then re-add it using the sync buttons on the RBR and RBS. The re-add should sync the PW to the RBS for whats set on the RBR.
todddel68 wrote:I have the same setup and it doesn't sync the admin password. I had the satellite reset and synced again but it didn't do anything. Changing the pw on the router is never synced onto the sat. This seems to be a common problem judging by the threads here which for some reason I cannot reply to as a new user. Some have it, some don't.
FightingFurball
Jul 27, 2019Aspirant
I had a similar problem signing into the Orbi Satellites after changing my password on the Orbi Router. In my case, the initial satellite login always failed (I think it was a 404 message). But if I just did a browser refresh,, I was then logged in.
I have lived with this situation for awhile but it has now been resolved after I updated the firmware to version V2.3.5.30. FYI, I did the automatic "Update All" method, not the manual update.
