bLUEJAG69
Mar 22, 2020Aspirant
How do I configure my WAP2 OR WPA3 security type?
How do I configure my router and my new NETGEAR_EXT connection to be secure WAP2 or WAP3 security type
bLUEJAG69
Hello
I tried to navigate to "my wifi dot net" which is in the instruction
It seems to be down.
This is in the instructions, so if this is where I need to go to find the “Orbi web interface”
Might need some more help.
Maybe I should just ask where or how do I find the Orbi web interface?
CrimpOn
Mar 22, 2020Guru - Experienced User
bLUEJAG69 wrote:Maybe I should just ask where or how do I find the Orbi web interface?
Sorry. We tend to forget that most people do not do this all day, every day.
The Orbi web interface is usually at http://orbilogin.net. If that doesn't work, then look for the "gateway" IP address that has been assigned to your device, often 192.168.1.1
When the Orbi came "out of the box", the login credentials were "admin" and "password". It is not possible to change "admin" (nobody knows why), and the user is URGED (almost forced) to change the password to something more unique.
