Anklejive
Dec 31, 2017Tutor
How do i connect an allowed device showing on the access control page as not currently connected.
I connected my new Orbi RBR50 system with two satellites yesterday. I have been to the Access Control page and turned on Access Control. There are 13 wired devices "Allowed," but in the list under...
Anklejive
Jan 03, 2018Tutor
Thanks for the answer, but I tried that. I get a small window that says the is a duplicate MAC address. I click OK and am back to the list of approved devices not connected to the network.
DarrenM
Jan 04, 2018Sr. NETGEAR Moderator
you may want to disable access control connect the phone and then enable it again.
DarrenM
- AnklejiveJan 04, 2018Tutor
Thanks, DarrenM. I tried that several times. Any other ideas?
- TedHLJun 25, 2018Tutor
You are not alone. I have tried all the suggestions on this thread and get the same "Duplicate MAC Address" dialogue window.
Only thing I can think of is the router has already detected the MAC address and thinks you are trying to add it as a duplicate.
I would like to enable access control but can't until this gets straighted out.
- mjdavis328Aug 03, 2018Aspirant
I just installed RBK50 this evening.
I use ATT Uverse and I set the gateway as a Passthrough so use the Orbi as the main router.
I assigned the Orbi IP as 10.0.1.1 (this is same setup I used for previous Airport extreme and all functioned properly until the AE died)
I have a Speco DVR camera system attached via ethernet. I assigned it a fixed IP of 10.0.1.15. I forwarded the appropriate ports (5445, 80) and confirmed they are also on 10.0.1.15. When I set the DNS access on the Speco system I get a confirmation that it is connected to the internet and ports are forwarded properly.
However, I cannot access cameras via the internet. When I go to Access control (I have it off) and see connected devices, it shows the DVR with correct MAC address as an "allowed device that is not connected." I have reset everything multiple times, and cannot get it to connect.
I also have a Rachio sprinkler control and iAqualink pool control that are having same issue (both connected via WiFi, however). But both show as "allowed and not connected."
Anyone else having this same issue?? Is it a problem with Orbi, my ATT gateway or other issue??
If I can't get these 3 things to work I will need to return this system as it needs to work with these as I use them daily.
Thanks!
- steve2502Aug 11, 2018AspirantHi Anklejive,
From what I’ve experienced myself with this problem on other Netgear routers, you have to first delete the device from the “allowed but not connected” list before you can add it as an allowed device. The MAC address of the device you’re trying to add is probably one of the “unknown” devices on the list and therefore already attached. Try deleting all the “unknown” devices on the allowed list and then try to add your devices again, you should be able to connect without any errors.
Good luck
