Anklejive
Dec 31, 2017Tutor
How do i connect an allowed device showing on the access control page as not currently connected.
I connected my new Orbi RBR50 system with two satellites yesterday. I have been to the Access Control page and turned on Access Control. There are 13 wired devices "Allowed," but in the list under...
Anklejive
Jan 04, 2018Tutor
Thanks, DarrenM. I tried that several times. Any other ideas?
TedHL
Jun 25, 2018Tutor
You are not alone. I have tried all the suggestions on this thread and get the same "Duplicate MAC Address" dialogue window.
Only thing I can think of is the router has already detected the MAC address and thinks you are trying to add it as a duplicate.
I would like to enable access control but can't until this gets straighted out.
- mjdavis328Aug 03, 2018Aspirant
I just installed RBK50 this evening.
I use ATT Uverse and I set the gateway as a Passthrough so use the Orbi as the main router.
I assigned the Orbi IP as 10.0.1.1 (this is same setup I used for previous Airport extreme and all functioned properly until the AE died)
I have a Speco DVR camera system attached via ethernet. I assigned it a fixed IP of 10.0.1.15. I forwarded the appropriate ports (5445, 80) and confirmed they are also on 10.0.1.15. When I set the DNS access on the Speco system I get a confirmation that it is connected to the internet and ports are forwarded properly.
However, I cannot access cameras via the internet. When I go to Access control (I have it off) and see connected devices, it shows the DVR with correct MAC address as an "allowed device that is not connected." I have reset everything multiple times, and cannot get it to connect.
I also have a Rachio sprinkler control and iAqualink pool control that are having same issue (both connected via WiFi, however). But both show as "allowed and not connected."
Anyone else having this same issue?? Is it a problem with Orbi, my ATT gateway or other issue??
If I can't get these 3 things to work I will need to return this system as it needs to work with these as I use them daily.
Thanks!
- FURRYe38Aug 04, 2018Guru - Experienced User
Modem Combo Units:
Couple of options,
1. Configure the modem for transparent bridge mode. Then use the Orbi router in router mode. You'll need to contact the ISP for help and information in regards to the modem being bridged correctly.
2. If you can't bridge the modem, disable ALL wifi radios on the modem, configure the modems DMZ for the IP address the Orbi router gets from the modem. Then you can use the Orbi router in Router mode.
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, LAN to LAN and configure AP mode on the Orbi router.
Thanks!
- ShawnBNov 06, 2018Initiate
I was having simular issues with trying to set-up a Netgear range expander with my Nighthawk AC1900. On the Access Control page of the NETGEAR GENIE The range expander was in the " Allowed devices not currently connected to the network" tab. I tried everything to get it to connect, but nothing worked. I went into the wireless page and saw that the box for "Enable Smart Connect" was checked. I unchecked the box. Then I reset the expander. I went thru the expander set-up one more time and this time it connected. Hope this helps someone.
- FURRYe38Nov 06, 2018Guru - Experienced User
We've found that with expanders, especially with NG's EX's, they have there own wifi handling and seems that the EXs prefer having two separate SSIDs at the host router, then let the EX expander either create one SSID thru it or separate. Seems odd behavior. I noticed this with my EX7700/7800s. They don't like Smart Connect enabled On the host router for some reason.
