gprasada
Jun 20, 2021Follower
How do i connect my existing NBN phone to the Orbi router
Hi I have an Orbi mesh system installed and the NBN modem plugs directly into the Orbi router, need some advise on how to plug my existing VOIP phone into the router so I can use it.
michaelkenward
Jun 21, 2021Guru - Experienced User
That will be down to the people who made the unnamed VOIP phone to advise. It may not be possible.
As this is an Orbi mesh system, if anyone does know what to do, they probably don't hang out here. You have posted your message in the section of this community given over to Nighthawk WiFi Routers. (This is easily done, given Netgear's complicated community structure.)
Many questions apply to different types of device, so there may be useful responses here, but you might get more help, and find earlier questions and answers specific to your device, in the appropriate section for your hardware. That's probably here:
Orbi - NETGEAR Communities
If you do want to ask for further help, you should provide a pile of more information, including, for a start, who made the phone, what modem you own and which ISP is involved.
As this is an NBN network, you might also get more help from a local source. This place seems to be good:
